Crank sensor issue jdm h22
Discussion in 'Civic and del Sol - EG and EK' started by ARC, Aug 19, 2007.
  1. ARC
    ARC New Member
    The Bahamas
    I am swapping a jdm h22a from a 95 jdm prelude for a h22a4. I want to know if the base pan and gear box will fi ton the jdm h22 and if the crank sensor can fit from the h22a4 and is the sensor doesnt fit if the car will run without it.
  2. bigjussin2
    bigjussin2 Junior Member
    yo
    it will only fit off a us h22a4 from a 1997 model ONLY, the oil pan will fit if u use the oil pump from the 97 as well....and lower timing cover..im haveing the same problem...i'll probably sell my jdm h22 and buy an h22a4
