Andrew
Active Member
Short and sweet since I'm in a rush to get this thing done.
*I have the Helms on PDF and it doesn't clarify this*
I've got the Flywheel held with a Crowbar.
In order to loosen the crankshaft pulley bolt, do you loosen counter-clockwise or clockwise(is it reverse threaded so-as not to spin the motor?)?
Thanks! Hopefully someone can read this soon, I really need to get this timing belt replaced.
-Andrew
Here's what my Helms says:
Maybe I just don't clearly understand what direction exactly I'm supposed to turn to loosen it.
Any help would be great!
Thanks
-Andrew
-Andrew
Thanks
-Andrew
