Crankshaft pulley fall off !! Timer belt Shifted 80% out about to fall off.
osix
While going out on a ride today . if i recall correctly i was driving toward a redlight and ai heard a loud banging sound near the engine . thinking i hit some kinda stone or a reflected pebble . i drove for another 100 meter or so before i notice the battery light came on . and the engine seem to different . so i stop to have a look . about 500 meter down the road.
Saw a few belt hanging . Mainly the Aircon ./ dynamo / and one other belt .
Reach under the bumper and notice the Crankshaft pulley hanging by the pulley belt
The Timer belt is like 80% falling off. I try to push it back a few time and start my engine but it keep shifting outward as if it would slip off i repeat that almost 4-5 time and each time it shifted outward .
now i pondering what do i need to take note and save my New Toy .
The timer belt i only manage to push the top part back in but the lower part is hanging on the edge of the gear. once i start the engine the top part of the belt would shift itself outward as if it would fall off .
Your crank pulley has a bolt and a key. Im guessing you've lost one or both. It's hard to say but it is possible that it has done some serious damage.
The bolt Broke off. And how i just lifted the engine i will update more photo soon
Did you get the rest of the bolt out of the crank? Did you damage the valves or pistons? I know a tired timing belt that breaks can ruin an entire motor. Sometimes, people get lucky (belt breaks at idle and motor is shut off immediately). This situation seems very similar.
i am replacing the Crankshaft .
and got a new one today .
While fitting i find that the Bearing inside is too small ?
The crankshaft bearing need to be larger. almost 2mm i think .
Any idea anyone ?
i also got new timer Belt . The seller gave me Honda City Timer belt is it the right one ?
This is not the photo of the crankshaft i got . But just an example .
i found a crankshaft . but when i try to fit it .
Mine seem to have a larger Diameter of point " a " and point " b "
i try to fit it with the old crank bearning and seem like it too small .
every part is the same .
only the Shaft between is larger .
Is it better ?
Do i try to find a another Crank bearing to fit it
What happen why the old Crankshaft have a smaller diameter on "a & b "
almost 2 mm .
