It's NOT reverse thread, i think he means the way the pulley actually sits inside the timing cover/block guarding on the bottom, on top of a gear with a small key to hold it in place.Quoted post[/post]]
It is in gear.. and you mean countersunk like reverse thread?
Quoted post[/post]]
Go to a local mechanic and ask if you can borrow an impact wrench for 2 seconds. That is literally all it takes. Every other method sucks, and takes a long time. Using an impact gun. I was able to replace the timing belt and reset the timing in like an hour.
Quoted post[/post]]
I had issues with my Sube pulley, I called Unorthodox and they told me to put the car in 5th gear. Then have someone hold the brakes while you Tq or remove the pulley.
