crankshaft
Discussion in 'HYBRID -> EP / DC5' started by civicboy1, May 10, 2007.
  1. civicboy1
    civicboy1 New Member
    iv had my engine light on for about a week now and im scared to drive my car at first when i got a diagnostic it was a code p1337 and auto zone said i needed to replace my spark plugs so i did that and it still didnt go off so i went back and it was the same code but then they said that i need a crankshaft positioning sensor.
    does anybody know where this is on a 97 teg, can i replace it myself, and if so can you give me guidence
  2. TurboMirage
    your code is leet....
  3. civicboy1
    i dont really know wat leet is, sorry
  4. suddog
    suddog New Member
    Travis AFB
    Did you ever find out where your sensor was? I also have a 97 integra with the same trouble code.
    I replaced the whole distributor and it changed nothing.
  5. BrutalB83
    Rochester Hills, MI
    Do you realize you're in the wrong forum? This forum is for 01+ Civics and RSXs.
    Anyway, have you tried resetting your ECU?
  6. suddog
    suddog New Member
    Travis AFB
    I didnt realize I was in the wrong forum, but thanks for the info. I cleared the codes with the scanner, but I am unsure how to actually reset the ECU.
  7. BrutalB83
    Rochester Hills, MI
    Resetting the ECU is easy. Just unplug your battery or pull the ECU fuse, let the car sit for a few minutes, reconnect everything, and then turn the car on and let it idle for a while, maybe take it for a drive.
    If the CEL comes back after you've done that, then you know it's serious.
