Crazy Idle problem on B16a crx
Discussion in 'Civic and CRX - EF' started by 34diesel34, Jan 28, 2014.
  1. 34diesel34
    34diesel34 Import Tuner
    USA
    I'm having a crazy idle problem with my crx si. The idle is very high and constantly going up and down and staying between 2000 and 4000 rpm. I disconnected the battery and reconnected it a few times to reset the ecu but this problem will not go away. What is causing this????????
  2. eg6sir
    Have u checked for vacuum leaks?
  3. Briansol
    vac leaks, air in coolant, bad IACV
    are the first things to check
    is it throwing any codes? done anything recently to it?
  4. 34diesel34
    USA
    It's not throwing any codes on the ecu. I saw a puddle of coolant underneath. This makes me think it could be air in the coolant. It's going to be hard to work on it today. This is what's going on here Picture 021.jpg
  5. Briansol
    If you're leaking coolant, it's probably the problem. might have a bad water pump, hole in the rad or pipe/line, or popped the HG. check your oil to see if the later made it inside the oil...
  6. 34diesel34
    USA
    Problem was air in the coolant. It Idles smooth now. I still cannot find the coolant leak though.
