Crazy Speedometer
Discussion in 'Civic and del Sol - EG and EK' started by eg'sforlife, Dec 22, 2008.
  1. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    My Speedometer is going crazy it starts moving sporadically if i rev past four grand
    or when ive been driving for a while it will drop to zero than it will jump back to actual speed and will consistently keep doing this
  2. austin20110
    austin20110 New Member
    Northern Va
    check connections behind the cluster
  3. MthaFuknGreen
    Lodi, CA
    stop slowing down and speeding up so much.
    youll fuck your tranny.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its a bad vss, or gauge or the alternator is going out or the fuse for it
  5. serrilion
    serrilion In my own little world! VIP
    Vermont
    I had a similar problem, it was snow and ice built up inside my stock stealy rims, once I cleaned them off in such it worked grate for a couple weeks haha!
  6. eg'sforlife
    29 stumps, CA
    im not slowing down and speeding up it started when i was going down the highway the reason i had it revved up was cause i wonted to see if it was going to do it when im sitten it neutral.................i dont get snow but i do think its a connection cause if i try as hard as i can to shake my dash it does move
  7. efhondakid
    Akron-Canton, Ohio
    My speedo in my EG does it every now and then, youll just be driving and itll drop to zero and then bounce back up. I would have to say its your VSS taking a crap.
  8. dacheat
    dacheat ..is grounded.
    strongbadia
    is there a lil hiccup in the engine when your rpms get all crazy? - not really very noticeable, but just a slight disruption in the normal sound/power?
    if so - this sounds just like when my ignition module in the distributor went bad. you could check that.
    :shrug:
  9. General Lee
    General Lee New Member
    B.C. Canada EH!
    are you running a stock ecu? because mine did that when a ran the obd2b ecu on my 99' b16a. the right ecu solved the prob for me.
  10. eg'sforlife
    29 stumps, CA
    pulled the cluster apart and sure enough a connection was barely hanging on hooked it back up and bam it works
  11. efhondakid
    Akron-Canton, Ohio
    You need one of these.
  12. eg'sforlife
    29 stumps, CA
  13. efhondakid
    Akron-Canton, Ohio
  14. Ethan
    Ethan Well-Known Member
    ROLF OMG hellz yea me too!
  15. eg'sforlife
    29 stumps, CA
    i have one there free when you buy an ass load of stuff at staples
