crome b18
Discussion in 'ECU's, Electronics, and Tuning' started by stedscivic, Jul 12, 2005.
  1. stedscivic
    stedscivic Senior Member
    so i got my p28 setup with dataloging and crome
    messed around a little bit to see if it works and it does so thats awesome
    heres the guestion
    is the usdm b18c1 maps the same as the jdm b18c?
    i didnt run the car long enough to see how it ran i just wanted to make sure that it worked
  2. pissedoffsol
    they are slightly different
  3. stedscivic
    how much difference between the two
    what could i change to get as close to a stock jdm b18c as i can get?
  4. pissedoffsol
    who cares... take it to a dyno and tune it with a wide band. you'll make more power anyway.
  5. stedscivic
    so ill be alright driving around for a while until i get it tuned
  6. smooth_criminal
    smooth_criminal Senior Member
    It should be just don't take it in high rpm's incase it's leaning out to much.
  7. stedscivic
    [/quote]
    [post=525614]Quoted post[/post]​
    [/quote]
    so going to the strip is out friday then what is a high rpm to you 6k or higher
    glad i still have my p72
