crome?
Discussion in 'ECU's, Electronics, and Tuning' started by hondacrxb16vtec, Sep 18, 2006.
  1. hondacrxb16vtec
    hondacrxb16vtec New Member
    lemoore, califoria
    is this a good programmer?
    i've been hearing alot about it.
  2. CrazyAzn
    CrazyAzn Senior Member
    from what i hear is good, from what ive seen its pretty good. i made 180whp off of it, but from what im told it has a hard time controling the idle correctly.
  3. pissedoffsol
    it's what i tune with almost exclusively. Best tool for the money IMO.
    Sure, there's better... but you'll be paying out the ass for it.
    < C R O M E >
  4. hermsfab
    hermsfab New Member
    I use it, worked flawless so far.
  5. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    It shouldn't have trouble controlling idle unless the stock map was altered near the idle, which you should not need to do on any application. Crome is a great program - easy to use, and lots of good tools built into it. You won't find better software for the money.
  6. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    I'll be using crome too. From what i hear , its easy to use.
  7. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    On pgmfi.org there's a LOT of instances where people are getting the bouncing idle wit Crome. There's a delete script for it but I havent tried it yet so I cant see what it does.
    Otherwise Crome is Badass! I was able to learn the software by just working with it over and over. Its all in relatively plain english :)
  8. Epox_Ardere
    Epox_Ardere Junior Member
    I actually got rid of my bouncing idle problems by switching to crome. There is deffinitely alot more functionallity to it then something like uberdata.
  9. CrazyAzn
    i got it tunned at churchs, and they basically said its hard for crome to control the IACV, or it doesnt control it as good as lets say, hondata does. Its fine most/60% of the time. the rest of the time it just bounces around and annoys me. Butttttt my car runs freaken awesome if it isnt idling.
    so if crome could fix that issue, that would be sick. . .. !!!!
  10. mysi92
    mysi92 HTI Werkstatt
    7525 BRANDT PIKE-45424
    I'm using crome in my 5gsi with b16, Dave who burnt my chip has a website dedicated mainly for crome, check it out....
    Welcome to PGMFI
  11. GSRCRXsi
    MD
    im tuned on crome. 215whp all motor OE parts bottom end. great tool. :thumbsup:
  12. LateApex31
    LateApex31 New Member
    I've idled lots of 1200cc injector cars and a few 1600cc setups perfectly with Crome. Idle stability requires tuning and an understanding of what those numbers in the boxes mean.
  13. pissedoffsol
  14. CrazyAzn
    i would think church would noe something about what those numbers mean. . .
    woops am i trend jacking?
  15. hondacrxb16vtec
    lemoore, califoria
    so i can download the software myself and tune my own car? what equipment would i need?
  16. Turbo&Auto
    East Burg, PA!
    A laptop, chip burner, chips, software, socketted ECU. The chip kit is only like $24. If you have some soldering skills its VERY easy to socket your own ECU.
  17. hermsfab
    hermsfab New Member
    a wideband also helps
  18. Turbo&Auto
    East Burg, PA!
    And for a turbo car, make sure to get a EGT gauge ;)
  19. reikoshea
    Dallas, TX
    what, did you see me commin?
  20. Turbo&Auto
    East Burg, PA!
    I knew when the Wideband came out that the other essential gauge would be mentioned :)
