Originally posted by preluderjs@Dec 20 2003, 11:19 PM
Read up, do some searching/ homework.
https://hondaswap.com/forums/index.php?...l=brembo+blanks
(cut and paste that if it doesnt work)
Originally posted by NoJokE@Dec 20 2003, 11:14 PM
Blanks are the best. More surface area with which to stop with.
BUT if you are set on getting one or the other of these, go with slotted, less material removed then cross drilled.
Cross drilling weakens the rotor and provides far less stopping power then blanks and less then slotted.
Originally posted by MXDesa@Dec 21 2003, 10:36 AM
Your correct but that surface area also creates more heat and makes it harder to get rid of the gases that build up from over heating. Cross-Drilled and/or slotted rotors can give u better stopping power because they remain cooler. If there were useless and a waste of money, ferrari and porsche wouldn't use them on all there cars. But make sure u get a quality rotor
Originally posted by UDT@Dec 21 2003, 10:30 AM
i think the idea about cross drilled and slotted has to do with heat and needing to get rid of it.......if you know what i mean, kinda like heat sink on an amp
my auto tech teacher told me the drilled rotors are for drag racers and actually intentionally reduce contact area to reduce chance of wheel lock from high speed breaking, and are not for cooling(that is what the vents are for).
im guessing slotted rotors are so the pads will bite gradually and not all at once, or something of that nature.
You are right too, to a certain extent. Ferrari and Porsche use them because 1) At 180+ miles an hour heat DOES build up very quickly(your Honda isnt gonna see 180 on the street), 2) they also have 13+ inch rotors and 4 pot calipers, so what they lose in surface area they make up by having huge rotors and excellent clamping.
So for a street Honda, get some blanks, unless you do some hardcore road course and/or endurance events.
Originally posted by E_SolSi@Dec 21 2003, 03:06 PM
its not about heat its about weight
Originally posted by NoJokE+Dec 21 2003, 04:59 PM-->E_SolSi@Dec 21 2003, 03:06 PM
It IS partly because of heat, it does let it vent better(this is only beneficial when you are racing for extended periods of time, again NOT for a street Honda). Most aftermarket pads have heat ranges, and if you are running cooler then what their heat range is, your braking are gonna feel like shit. If it didnt have to about heat, blank rotors wouldnt have the slots in between both of the sides. Cross drilling is for both weight AND heat.
Originally posted by Loco Honkey@Jan 3 2004, 08:54 PM
Why the hell are any of you talking about outgassing? Todays carbon metallic pads contain NO organic material, therefore producing NO gas. Cross drilled rotors are a byproduct of '30's technology when brake pads and shoes were made out of leather. Cross drilled rotors crack. Slotted rotors wear pads. Proper bedding and pad selection will eliminate glazing. The reason Porsche and Ferrari use them is hype. Everyone, including everyone in this thread, thinks that cross drilled rotors = high performance. That's total and utter bullshit.
1) Cross drilled rotors have less swept area.
2) Cross drilled rotors have less surface area to absorb heat.
3) Cross drilled rotors have less mass to dissipate heat.
4) Cross drilled rotors crack and break (seen it twice at open track days).
