Crossmember help!!
redlinerz
Member
I am putting a b16a into my crx and there isn't any clearence for the header.... should I just cut the crossmember to make it fit? Also is there any online how tos that can help me out? thanks
when i put the b16a in my hatch i cut the crossmember to fit, atleast on my hatch i only had to cut like a half inch
So I can just cut like half an inch and it should be fine? And what would happen if the crossmember should break one day that I am driving? And can I just bang it in with a sledge hammer instead of cutting it?
DON'T cut it. Beat the shinola out of it!
If you have the money, and upgraded crossmember is a very wise investment.
all i cut was the lip off the crossmember, i am a mechanic it is not gonna effect anything. that or get gsr headers i do believe they are alittle smaller
I just beat the shit out of it until the header fit. You only need to make a 4" wide, 1/2" deep dent and you'll have clearance.
what do you think of a place racing crossmember? is it worth it? and how do I order one since they dont got a website up.. someone had told me it was about $150.. thanks guys
not worth it, if your gonna put out money for one get one that will help w/traction, like the jim fab or z10, but for 150, just smack that mutha
we have this exact thread going on honda-acura.net,and if your the same redlinerz that i think you are we, coverd it.i used a die grinder,the gsr headers a longer not shorter.i have a dc header from a gsr on my car now and it grinds because it hangs to low.i also cut the lip on my crossmember and beat the ever loving fuck outa it with a sledge hammer,keep in mind its pretty damn strong.if you have a torch i would heat it up first and then wake the shit outa it.
i am using place racing mounts in my crx and i have no clearance issues with the header i am using (matrix header for an LS) while on the subject...i didn't even have to bang in the shock tower for the alternator pulley clearance...it's wierd if you ask me because every swap i've ever done using these same mounts, they all have clearance issues.
