crower 412's
Crix
Will I need to check my clearances using the 412's? I figure since ive already got the vavlvetrain to do this I might as well get some wild cams to. Any advise?
if your using a stock piston and stock valve, and recommended cam gear degree. they will clear.
if you do anything else, i would clay it up
yea I will be using stock vavles. What do you mean cam gear degree? Like 16 degree?
most crower cams need to be degreed. the instruction manual will tell you to put the intake at like + 2 and exahust at -1 or something.
