They'd be a big mistake in an otherwise stock engine. You need more compression and a port/polish is absolutely mandatory.
You can mill the head quite a bit as long as you have adjustable cam gears to degree the cams with. In fact, it's actually better because you don't get a big piston dome that splits the flame front, causing a less complete burn and "cool" spots. Flatter pistons are better for flame propagation.
