alexfleury
Hope I am posting in the correct forum. I did try the search function and didn't find anything useful yet. I have a 91 4 door. the cruise control has always worked but after going to the shop for them to troubleshoot the auto seat belts, now the cruise doesn't work. They found that a previous owner had just disconnected everything associated with the belts and afer hooking it all back up the belts work fine. But now the cruise doesn't work
What are the most common failures for Cruise? If it is the control module, where is it located? I can't find a fuse listed for this function. Is there a separate fuse for Cruise? If it is an electronic failure is the control module expensive? Should I be able to find a used one here?
Can anyone give me any helpful hints about how to troubleshoot this problem? The "Cruise" light on the dash comes on. I have checked the switch on the clutch pedal. What else can I check?
Thanks guys, any help will be greatly appreciated.
Alex j_alexfleury@yahoo.com
