crx b16a2 swap blowing inner cv-joint. HELP!
Discussion in 'HYBRID -> ED-EF / DA' started by killme413, Sep 13, 2005.
  1. killme413
    killme413 Junior Member
    Hi.. my CRX -89 with b16a2 y21 swap is blowing my inner right cv-joint when turning wide =( Im using honda crx VTEC axels, my question is shuld i use VTI axels? My guess is that my VTEC axel is too short.. it looks relly extended when fitted..
    Is VTI axels longer then VTEC?.. or what other axel can i use? My guess is that im missing like 10-15mm
    thanx!
  2. 4drcivicb18a
    4drcivicb18a Member
    philly, PA
    Did you remove the dust seal on the wheel hub? That will cause it happens to everyone that dosent remove it.
  3. killme413
    hmm.. whats a dust seal!? x( hmm.. why is it there if it shuld be removed?..
  4. 4drcivicb18a
    4drcivicb18a Member
    philly, PA
    Its a seal on the inside of your drivers side hub. Take out both axels and look at the hubs only the drivers side has it (pretty sure). Take a hammer and a flat head screw driver and take it out. I put a b18a1 into my 91 civic and i blew an axel on wide turns, I was using 90-93 integra axels. Do a search its a well known thing
  5. drpenguin
    drpenguin Senior Member
    Salem, Or
    is your engine sitting in there right? I have seen people with those shity mounts that dont put the engine in right and there blowing cv joints left and right. I use teg half shafts from what im told.
  6. jdm2gen03
    jdm2gen03 Senior Member
    yep jus had the same problem. jus finished my swap of a b16 into my integra and did a touge and busted the right inner cv joint seal and now inner wheel well has cv grease everywere. but when i replaced my LBJ on the driver side we removed the dust seal. so no more problem.
