Crx B61a Injection
Discussion in 'HYBRID -> EG-EK / DC' started by iluvmyCRX, Mar 24, 2003.
  1. iluvmyCRX
    iluvmyCRX Junior Member
    Im needing to switch from DPFI to MPFI and I found a resistor box from a 90 Civic SI and I was wondering if the wires, connectors, and all are the same as the 91 CRX DX and if it will work.
  2. HOOKUPSPROCRX
    HOOKUPSPROCRX Member
    upland ca
    yes you can use the resistor box from the civic si or from a 90-92 integra. you will need to have your dx engine harness converted to run your motor . my shop does this for 150.00 and the harness will look completely factory including all clips to mount it.
