crx bseries swap help
Discussion in 'Civic and CRX - EF' started by hades1998, May 25, 2008.
  1. hades1998
    hades1998 New Member
    Houston
    i need some advice on a bseries swap into my 90 auto crx dx..
    here is a list of parts i have.
    93 ls head and intake
    90 auto ecu
    stock gsr headers
    96 obd2 ls longblock/w intake,injectors
    now a little more about what im lookin to do with this swap. im lookin to replace my stock motor with a stronger motor.dont need to be the fastest...just a little faster than normal.i think im going to keep the car an auto... im use to rewiring motor harnesses to get things working properly....thanx
  2. hades1998
    Houston
    anyone have some advice on getting a b18b1 obd2 engine into a 90 crx dx.....like what harness,wiring that needs to be done....im a first time honda owner....
  3. drummingpariah
    drummingpariah Author of the Madness Man
    Bay Area, CA
    I'd suggest a DPFI to MPFI conversion, then either converting the engine to obd0 (distributor is the important part) or getting the obd1 conversion from rywire and an obd1 ecu. I just noticed the rywire harness includes the DPFI to MPFI conversion! Rywire - Online Store
  4. hades1998
    Houston
    crx wiring
    so the wiring kit will allow me to use what i have listed?:confused:
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no...you have a little of eveyrhting..obd0.1.and 2...you need to get everything of one of them
  6. drummingpariah
    Bay Area, CA
    What you've got:
    • CRX DX wiring harness: Dual-point fuel injection (DPFI), obd0
    • b18b1: Multiple-point fuel injection (MPFI), obd2
    • 90 pr4 ecu: obd0 Integra ecu
    • b18a1 head and intake mani: obd1 (b18a1 obd1 versus b18a1 obd0)
    • GSR headers: may not fit, vtec heads are shaped differently than nonvtec heads, exhaust ports may not line up.
    What I suggest:
    • CRX DX wiring harness, converted to MPFI
    • rywire harness from obd0 to obd1
    • obd1 ecu (pick your flavor)
    • b18b1 block
    • b18a1 head + intake manifold
    • b18a1 exhaust manifold
    • custom cat-back exhaust (I haven't found a premade exhaust that fits correctly)
    sell/trade everything else.
  7. hades1998
    Houston
    ok i see thanks for all the help
  8. hades1998
    Houston
  9. drummingpariah
    Bay Area, CA
    You own a p75, an obd1 ecu. The p3 came after your car.
