Well before I went and drilled out the rivets I took a can of flux remover for soldering and sprayed down the contacts on the TPS and the connector, then I cleaned them with acetone followed by 99% isopropal alcohol. Pulled the ECU and Hazard fuse, reset the ECU and all is well.
