gettocrx
Member
Hey everyone! I have a 88 CRX Dx with a CRX Si head thats boosting 5 psi! The problem is that my motor wont run at Top Dead Center! Its either I run it @ 6 degrees advance or the bottom end power is lost if the advance is less then 6. If the timing is closer to TDC I lose a lot of bottom end power to drive on the street but the car runs great at top end! What should I do or what did I do wrong during the head swap (88 si distributor, camshaft, manifold with injectors and resistor box)? I just want this motor to get me around for now but I'm planning to drop in a D16z6 in after this motor blow or whenever I have time! I just want some top end power but still have bottom power for the street!
