Crx Ecu???!!!!
Discussion in 'HYBRID -> ED-EF / DA' started by rawerz, Dec 2, 2006.
  1. rawerz
    rawerz New Member
    Texas
    I have a 1990 Honda CRX that I just bought in a non running condition. The first thing I check, seeing as to how it doesnt run, the ECU for any codes. I get NOTHING, not even one blink. I checked my battery, terminals, and reconnected the ecu cables. I turn over the car 2 clicks and still no blinks?
    Does this mean i need a new ECU? or whats happening?
  2. charliemopps24
    charliemopps24 Junior Member
    Check the main relay and the fuel pump. Maybe the distributor too.
  3. rawerz
    rawerz New Member
    Texas
    Would that cause the ecu not to blink at all??
  4. reikoshea
    Dallas, TX
    well it could be that its an electrical problem that wont be recorded in the ECU. Does it crank but not start?
    Where in texas do you live again. I might be able to look at it if you are in the dfw area.
  5. 2in10se
    2in10se New Member
    Check your fuses??
  6. rawerz
    rawerz New Member
    Texas
    Checked my fuses and they are good. Tried a difefrent battery and still no blinks. I checked for fuel and I get no fuel at all but I still have a spark. It turns over fine just will not start, of course due to no fuel.
  7. reikoshea
    Dallas, TX
    main relay ftw.
    time to drop the tank and see if you have power at the fuel pump.
    if yes, replace fuel pump.
    if no, replace main relay.
    if yes and fuel pump kicks on (loud buzzing sound when you turn the key to 2) time to really check over the fuel system.
    If it is either of those things, the ecu wouldnt know it.
  8. rawerz
    rawerz New Member
    Texas
    I guess im going to go threw the fuel system then...
    Another question.
    I thought the ECU was suppose to blink at least once , like a "hello im alive" blink?
    Is that true?
  9. reikoshea
    Dallas, TX
    on obd1 cars itll stay solid then turn off i think. doesnt blink again after that.
  10. rawerz
    rawerz New Member
    Texas
    Well I get no light at all! Not even an intial blink.
  11. reikoshea
    Dallas, TX
    if its your fuel system, the cel wont tell you much more than i already did.
  12. rawerz
    rawerz New Member
    Texas
    I get no solid light at all....
  13. rawerz
    rawerz New Member
    Texas
    Ok now. I was checking and I have no fuel coming threw the lines and now my motor wont even turn over just the starter will click.
    But I crawled back under the dash checking the fuses and the "starter solenoid valve" 10 amp fuse pops everytime I turn the key over. And the fuel pump only clicks one time very swiftly.
  14. klyph
    klyph Dismember VIP
    North Pole, AK
    Sounds like the starter solenoid is short circuiting. Replace that and charge your battery, cuz it might be dead from all the cranking.
    As far as your fuel, could be the fuel pump relay, or the fuel pump itself. The lines should pressurize when the key is on, so if this doesn't happen (assuming the battery has a charge). Then you need either a pump or a relay. Test the relay before you go and drop the fuel tank.
  15. rawerz
    rawerz New Member
    Texas
    Is the fuel pump relay and the main relay 2 different things? If so where is the fuel pump relay located?
  16. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    It's on the left, left of the coin box. Pretty difficult to get to if you're big(hell, I had a hard time and im 5'6).
    Yes, theyre the same thing. The main relay is two relays in one box.
  17. rawerz
    rawerz New Member
    Texas
    Ill take a look in the morning. Thanks guys.
  18. nikozai
    nikozai New Member
    Alright, here's my thoughts about what's goin on here.
    1. Stop obsessing over your ECU light
    2. reikoshea has told you what could be causing that 3 times and you fail to understand what he's talkin about.
    3. This is an electrical problem.
    4. That means you need to use a volt meter and check circuits.
    5. The main relay is under the dash by your left knee and is responsible for turning on your ECU and Fuel pump when you turn the Key to the ON position.
    6. That COULD be why your ECU light isn't blinking once.
    6a. Or your ecu could be shot
    6b. Or the LED on the board simply doesn't work, rare but happens.
    7. The causes listed in #6 is what we're trying to nail down.
    8. If you have another ECU handy, throw it in and let us know if the light blinks.
    9. If you don't have another, then do what we're sayin to do to find out if the main relay simply isn't coming on.
    10. If your starter clicks but can't turn the car over, your battery is dead. Charge it. If it doesn't hold a charge, replace it.
    Now read #5 again.
    Then #4.
    Now use the volt meter and check for 12v+ at one of the 2 or 3 wires at the Fuel Pump when you immediately turn the key to the ON position.
  19. rawerz
    rawerz New Member
    Texas
    The main relay was bad. I ordered a new one from parts train today. Ill update after I get it. Thanks guys. Sorry about the hard head.
  20. nikozai
    nikozai New Member
    haha ;) next time go to the junkyard and pull one out of a car.
    What did you pay for it new?
