CRX F/S, Full b16 Swap F/S
VTECPOWER
I am selling my 88 crx dx as is, with slight front end damage, needs: Hood, Drivers Side fender, bumper has 2 small cracks in it, but is not necessary to replace, will include "jdm style" corner lights, all amber.
Zipcode: 22655
If you do not like the price, do not post, it's that simple, a lot of work has gone into this car, along with a lot of money over 8k invested and all the work has been done by myself and my friend, he is a member on here was 89crxdx1, and now his name is redCRXdx, and can vouch for this car.
Price: 6,000 obo
I can take parts off of it if you would like the price dropped.
Mods:
Engine:
JDM B16 engine swap from hmo w/ lsd trans
Wiring from rywire
obd0 w/ pr3 ecu
Haport mounts/shift linkage
Excedy Stage 1 Clutch
No a/c
RSR Ex Mag Exhaust
Short Ram Intake
Skunk2 Pro Series Intake mani
Hondata IM Gasket
AEM Fuel rail/FPR
B&M Rail mounted Fuel pressure gauge
Test Pipe
Short Shifter
Short Shifter Bushings
New Alternator
Wheels:
GSR Blades w/ 195/50r15 falken ziex 512 tires
Steelies included
Brakes:
15/16" MC
New Brake Booster
Goodridge stainless lines
Brembo front drilled/slotted rotors
Axxis Pads
Remanu. Calipers
New hard lines for rear drums
New rear drum pads
Suspension:
Tokico Illumina's
Skunk2 Springs
Avid Racing Traction Bar
New shock bushings (enery suspension)
Interior:
Autometer Gauges (Volt, A/F, and Oil Pressure, 5" Tach w/ shiftlight)
3 Pillar mount for gauges (autometer)
Hunsaker Seats
JDM Shift boot y0 (red stitching)
New Black carpet
Pioneer 4 Way speakers installed in car, does not come with a cd player, can come with jvc radio, but the cd part does not work.
Grant GT 13" Steering wheel (Smaller than stock)
Can post more pics: Ask for specifics.
I'm sure I have forgoten some of the things that I have done to the car, so if i remember it may be updated.
EDIT:
Lighting: Fairenheight Bulbs w/ headlight harness, does make a big difference, bulbs are silverstar quality, but brighter with higher wattage.
New radiator also put in when swapped in June/July 2005.
EDIT: When swapped, new rotor/dist. cap, ngk plug wires, bosch +2 plugs.
Always used royal purple oil, 5.99/quart.
Already changed mtf 2 times, used honda MTF each time.
Bump for new pics here:
bump for a sweet car. alot of hard work and time has been put in to this thing.
bump for clean rex, with shit ton of parts
If I have someone who wants then engine as a complete swap, mounts/axles/linkage/complete engine/ecu/wiring (will only work on a dx engine), then I will part the rest out, let me know If you are interested in the engine or anything else, but engine must be spoken for first before anything else is sold, i believe i have seats, suspension, and test pipe spoken for if i part out, i also have a skunk2 68mm tb for sale as well paid $290, Sooooooo make me some offers on the COMPLETE SWAP from HMO, local only, as you would have to pick it up.
BUMP
Taking off manifold/gauges/shocks springs/wheels
Price will be 4300obo
Traction bar stays on unless i get a stocker to go on.
how much you want for the traction bar with swap of my stock one?
how much for a rolling chassis? i dont necessarily need the wheels or suspension, engine, or guages. i really just want the shell. if you had stock stuff to put back on that would be preferred. im really just interested in the barebones, as im only looking for a good condition body with little to no dents and no rust. i do want the brake stuff though, and the exhaust.
how is the condition on the body? get more pics of the damage. rust? hows the paint? etc.
I think im swapping out the suspension for stock off of someone, Needs new hood and drivers fender, the rear 1/4 panel has a crack from bondo, on the drivers side.
The only way i would sell the rolling chassis would be if someone would want the engine.
Interior is in good condition, replaced the carpet, brand new windshield as of late june 2005.
Paid $2500 shipped from h motors online.
I am looking for somewhere around 2500
Swap came with pw0, bought pr3. $140
Rywire wiring was $200.
Clutch was $300+
Alt. was $150
Tune Up $80
Oil Pan gasket.
Also engine has LSD tranny.
And motor is still in car and is dailt driven.
