Crx Headlight Swap
Discussion in 'HYBRID -> ED-EF / DA' started by IRuffPuppee, Jun 18, 2003.
  1. IRuffPuppee
    IRuffPuppee Member
    will a 90-91 CRX headlight fit on a 89 CRX . The only thing i notice was that the cornerlight screws are on the outside. :blink:
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I believe the headlights are the same shape- the brackets are just different. If you can reuse your 89 brackets with your 90-91 headlights, you should be ok. Use the corners for your year car.
