CRX HF/Si
Discussion in 'HYBRID -> ED-EF / DA' started by J89EF9, Mar 1, 2008.
  1. J89EF9
    J89EF9 New Member
    nor*cal
    Hi i would like to know if a 91 si distributor will fit a 91 HF since both are mpfi?
  2. roninallout79
    roninallout79 Plan B
    GER friggin MANY
    should. the si dizzy has two round plugs the dx has one round and one somewhat square. But I think your dizzys will swap
  3. slowlx
    slowlx Junior Member
    Hudson, FL.
    Check the code on mounting leg if it says td-02 then they are same.
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    Si distributor is TD02U and HF is TD18U, but either one will work
  5. monotech909
    monotech909 Got V-tec?
    Inland Empire
