I am placing a d15z1 (vx) engine in my 90 DX hatch. I have access to a CRX HF tranny, '91 I believe. Will I be able to use the clutch, linkage, torque converter, etc. from my DX , or will I need to get this from another car?
the HF transmission will bolt right in using your shift linkage, axles, etc. - as long as it is not 88 model, you can use your existing clutch - 88 transmissions only match 88 clutches
