Crx --> Integra Ecu swap
Discussion in 'HYBRID -> ED-EF / DA' started by baker423, Jul 2, 2005.
  1. baker423
    baker423 Senior Member
    Upstate New York, 14882
    Here is the deal...
    '91 Crx Si w/SOHC Zc swap,i wanna swap the 88-89 Integra ECU into it.
    I need to put the Teg ECU into the Crx Ecu casing so it will bolt into the car correctly. The Teg ECU casing will not bolt into the Crx, since the Teg case has different mounting points than the Crx.
    I have both of the Ecu's apart i just can't figure out how to get the circuit board out.All of the screws are out so i am not sure.I don't want to go yankin on it and break it,so does anyone have a clue?
  2. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Change the mounting points on the CRX and dont worry about swapping internals??
  3. 90crxb18
    90crxb18 Senior Member
    lake elsinore cali
    just use two of the mounts and bolt it down..thats what i did it worked fine, dont take a chance fucking someithng up by taking out the internals.
  4. baker423
    IS this Ecu swap even worth it? I plan on swapping a DOHC Zc into it to replace the single cam zc,worth swapping Ecu's then or not even then?
    I have heard the only thing you gain using the Teg ECU is higher rev limit and running rich.
  5. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    i would run the pr4 instead of the pg7 on the pr4 all you have to do is get a dremal and shave some of the loop away.i will get pics of my pr4 if you want
  6. baker423
    How can a pr4 run what amounts to a d series motor (SOHC/DOHC Zc)?
    I didn't think you can run a pr4,since it is from a b series powered car?
    Pr4 is from the 90-93 Integra?Is that not OBD1,unless you get the 90-91 Ecu from the Teg?
    If this does work,how can the 90-91 PR4 Ecu plug n play with the Crx and What type of gains/benefits are there with running the PR4.
    Someone clear this up for me!
  7. Dark91zc
    Corona,CA
    there are 2 pr4's a obd-0 and a obd-1 the pr4 i have is obd-0 and it is plug in and play when i was running the pr4 ecu i was able to chirp 3rd with it and the pm6 was able to chirp second and the pg7 could not chirp second. i was happy with the pr4 ecu. if you want pics i can take pics :)
  8. baker423
    What type of benefits are there to using the Pr4 ECU in a 91 Crx w/ either a SOHC or DOHC Zc Swap?
  9. Dark91zc
    Corona,CA
    fuel mapping :) for me
  10. ryan89crx
    ryan89crx Senior Member
    Washington State
    the pr4 was dyno proven to cause a loss of 15hp a couple years ago when Transzex, aka Mista Bone was doing testing.
    i ran the pg7 on my sohc zc and i loved it, higher rev limit, more fuel. no adverse effects at all. i thought it pulled a bit harder. just do like 90crxb18 said, use 2 of the mounting bolts. it works just fine
  11. Dark91zc
    Corona,CA
    when i ran my pg7 it sucked bad donkey balls my car could not get out of its own way to save it own life but the pr4 hauled ass
  12. ryan89crx
    Washington State
    funny, my PM7 right now runs smooth as butter, pulls real well too
  13. Dark91zc
    Corona,CA
    wait which ecu are you talking about pm7 or pg7 we were talking about the pg7 and i have never tried the pm7 for one reason 112 speed limiter :(
  14. ryan89crx
    Washington State
    oops, misread the last post. i have personally ran BOTH the pg7 and the pm7 on my a6. I liked the pg7 a lot, ran great, smooth, pulled well. i came across an offer to trade my pg7 for a virgin '91 pm6, so i jumped on it. i currently am running a pm6 chipped to pm7 specs. and ya, the rev limiter is there, but really, how often are you runnin over 112mph for that to be a REAL issue?
  15. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    PM7 or PG7 is just fine, I run a PM7 now, speed limiter is definetly there but thats not an issue, keeps me from speeding too much thats all. If you use the PG7, just modify the mounts or make some new ones with sheet metal or something, no big deal. I like the pm7, I did notice a little difference with power and the higher rev, but for some strange reason the pm6 starts and idles the car better until it warms up on mine. Switch them back and the problem goes away, no big deal tho. ;)
