hatukazi
ambitious...but rubbish
My best friend is close to completing his mini-me swap on his 91 crx Si.
done so far is:
head and head gasket from 98 HX (installed)
intake manifold and throttle body from 98 HX with injectors from 91 Si (installed)
ECU from 98 HX with conversion harness from rywire.
?'s I read on here that the Si distributor bolts right on a Y8 head or use the newer one from HX and re-plug it?
which timing belt to use? I have heard D15b and D16Y8 both and need to pick one.
I have also heard an adjustable cam gear is needed, but if I remember right they were using a Z6 ECU.
he also just got a header and I didn't take the one off my old HX so I dont remember 1 or 2 02 sensors?
we are so close to finishing this and want to get it right the first time
thanks for the help in advance .....
done so far is:
