look to buy a d16z6, found in the ex and si... try and get the full swap(mounts, tranny, ecu, wiring harness) to make things easier on yourself... you can use the tranny from your dx if needed and also you can modify(somehow)your existing wiring harness to work... although i would not recomend that... I cant think of anything else... keep asking if u need more info...
