crx oil cooler
Crx Kid22
im thinking about installing a oil cooler in my rex just wondering if anyone else has because i dont know exactly where i would put mine:confused:
I'm going to assume you don't need it, and will probably over-cool your motor(oil needs to be hot to work well).
well its going to be in some real rough conditions if i'm driving so... dont avoide the question if u dont have an answer
lol. Honestly, if you don't know where to put it, I'm sure you don't even know if you need it or not. I intentionally didn't tell you the answer, because, well, it's pretty much stating the obvious and oil that's too cold can still be harmful to your motor(this is why many use thermostatic valves).
The answer is SOOOO easy, I'll even give you a hint; Where's the other heat exchanger at?
Another hint: it's not the heater core.
