stud4u2c17
I drive my CRX HF, and after a while it starts to get hot, then i pull over and check and their is a bunch of radiator fluid under the overfill tank, i checked the limit and it was filled all the way up to the top... so i emptied it to the limit, and then i squeezed the radiator hose to hear for leaks and there was a pin size hole right under the radiator cap, so i plugged it, then i filled up about a gallon of water into it because it was empty, do u think its okay now? i know i dont have a blown head gasket, but what are other possibilities... theres only radiator fluid under the overfill tank... could that being to much cause my car to leak antifreeze? well thanks for you help
TJ
TJ
