crx rev probs
2fastteg
Member
i got a 89 crx dx i think and it revs fine until 3 grand and seems like its hitting the rev limiter or something i know i seen something for this i just couldnt find it
go here
https://hondaswap.com/forums/index.php?showtopic=29806
that will tell you how to check what codes you have and what they mean
the part that you need is about 1/2 way down the page
what code is being thrown will determine what needs to be done to make the car run properly
and "limp mode" is kinda like "safe mode" on your home PC... when a semi serious condition exists, it allows the car to run (barely) so you can "limp" it somewhere to get it fixed
but anyway, check out what code/codes you are throwing and we'll go from there
i tried it anad the ecu light just came on and stayed on no blinking i waited about five mins to see if it was going to blink
i read the directions the only thing i can get out of them is turn the igntion on and the light comes on i dont know what to do
are you looking at the check engine light or through the window on the ECU at the 4 LEDs
no i got the ecu out but i only see one red led light i had the one led blinking but it went into the teens when i counted the blinks
I had a friend have the exact same thing happen, his was a sensor problem, yours could be the same, or a fed ecu like you said.
