crx reverse light
team_lunatics
hi there guys and gals...i'm doing a h22 swap into my crx...i need to wire up the reverse light on the transmission...the engine harness i got does not provide the two reverse light plugs...which pins on the ecu plugs are the reverse lights???any help will be appriciated...thanks.....
Reverse lights don't go to the ecu plugs.
attachment.php
Connect the reverse light wires to the 6-wire square plug on the body harness thats on the shock tower. I believe its the two bottom wires, green with a black stripe and a yellow wire.
thanks alot...will try it out...btw is it the plug on driver side or passenger side....
No worries, I had to do an auto to manual swap on my EF hatch so I know all about it. :)
