Crx Rim Sizes
Discussion in 'Wheels / Suspension / Tires / Brakes' started by RFHOMI2U, Mar 21, 2003.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    I'm about to put in my coilovers, and the drop will be approximately 3". How big of a rim can I put on my car (still have stock rims) without the rims tucking and rubbing? i was thinking 16's or 17's but since the rims i'm looking at are not returnable, I don't want to get the wrong size. The idea here is to keep my car with a lowered look, and still have descent sized rims.
  2. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    16's. Heres why:
    1.) 17's on a civic are rice
    2.) Weight, you can shave a couple 10ths of a second of your quarter with 16's
    3.) your car WILL look lower with 16's
    4.) 17's look odd in a civic wheel well, mis proportioned to the size of the car too
    Thats my input.
  3. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
  4. Prowler
    Prowler Super Moderator
    B MT
    16"s if looks are REALLY important to you, otherwise go with 15"s. 17"s are rediculous on a Civic. I can see them on an Accord that is just a cruiser and only weigh 15lbs, but that's still a little overdone.
  5. pissedoffsol
    and don't drop it 3" ya ricer.
  6. sportlinecrx
    sportlinecrx Banned
    lol :werd: with a 3" drop. you will probably rub on 16's.
  7. Jspec
    Jspec Junior Member
    Vancouver, B.C. CANADA
    My buddies crx is dropped 2" and his 16's rub but not too much. I would definitly go no bigger than 16"s though.
  8. crxjdm34
    crxjdm34 Member
    if you go w/ 17's you will have to get a camber kit. without the camber your tire will be destoryed pretty quickly.
  9. 88civicHBz6
    88civicHBz6 Senior Member
    dude i used 18's on mine for show only but i drive with 15's and they look great on my but it's only a 1.2 drop. but i also show my car. 16's will rub if you go too wide of width. don't go big for daily driving.
  10. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    17s aren't rice. My car has 17s. My car is not rice. the 3'' drop would be the rice part. The misproportioning can be done on purpose to exaggerate the size of the wheel if you like the way that looks.
    as for responding to the real post.
    1. I would consider only doing a 1.5'' - 2'' drop. That extra inch can cause quite a bit of problems.
    2. I doubt 17s will fit under a 3'' drop
    3. 16s might fit, but also will probably rub/camber.
    4. if your heart is set on down 3'', I'd go with 15s or 16s.
    5. if you get 16s MAKE SURE you get the right OFFSET and the right WHEEL WIDTH. I believe the right thickness is 7 inches.
  11. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    dude mines dropped like 3.5 inches,( which i hate) but i have 16's and they dont rub at all. but if i was u, i owuld get either 15's or 16's. for one there lighter and u'll be faster and for two, no rubbage.!@
  12. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Here's my 16's on my car that was dropped about 1.5"... Looks pretty good, I think.
  13. Civic_88ls
    everett, wasington
    thats exactly the same wheels i have. hell yeah. mines dropped alot more tho
  14. stud4u2c17
    stud4u2c17 Senior Member
    my rex has 17's on it and its not ricey, looks perfect, 16's i think are to small for show, and 18's are to big for the wheelwell, the 17" has a diameter that fits the wheelwell exactly as it should, the whole wheel well is i think around 25" wide or around there, now u take that and subtract 17 for the rim size and thenanother 5 or 6 for the added on tire size and it gives you roughly the same curve as the wheel well, when you run 18's thats when it starts lookin funny, and i personally think 15 and 16's are a waste of money but im all for show, juss my 411
    but if i was you i would run 17's
  15. RFHOMI2U
    Nice hatch. I didn't think 16's would look so big. Nice. I'll go 16's. Sounds like a good idea. Thanks a lot for all the input guys.
  16. D See 2
    D See 2 Senior Member
    Baltimore, MD
  17. kyleirwin
    kyleirwin Retired OG
    Vegas
    :werd: those 16"s look too big to me on that hatch. 15" are the way to go.
  18. WhItE90CRX
    WhItE90CRX Member
    It all depends on what you want... if you wanna go autoxing then get a bigger wheel with a lower profile tire... it isnt rice if the smaller sidewall is better for handling.. just my .02.
  19. E_SolSi
    you have a lot to learn
