frogger1169
i bought a 89 crx with a zc second gen motor in it, fouls plugs horribly all the time. it has the honda distro in it and im sure i need the integra one. what i need to know is if any part of the harness or ecu has to be changed. it also has a sensor that is not hooked up on the other cam beside the distro. while my ecu that is in it run this car properly and will the ignitor work as well. i also need to know if the injectors will work. right now it is running on just one cylinder because it has fouled the other plugs. i put new ones in it and it almost immediately turns them black.
