crx shell with h22
Discussion in 'HYBRID -> EG-EK / DC' started by mwvnos, Nov 10, 2002.
  1. mwvnos
    mwvnos Senior Member
    SC
    how hard is it to fit a h22 turbo into a crx shell. i dont care if it is streetable or not. i want speed. what do i need to fit it in. i know a mount kit and wiring but how about the turbo set up. will i need to do a lot of fab work to get it in?? thanx
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    it is going to cost alot and will be a tight squeeze, you might even have to make the bay a little bigger
    ps. i own the 14,000 post
  3. mwvnos
    SC
    i thought so but i dont really know what ill need. ill probably end up trailering it. if it is goin to be more hassel then its worth then ill do it in a 5th gen civic hatch. ;)
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  5. mwvnos
    SC
    that doesnt sound like too much work for me. i really wanna do it in the crx. ill probably end up doin it. puttin a turbo on somehow and maybe a lil funny gas. ill have to research it a lot to see what i need. thanx!!
  6. pissedoffsol
    what gen crx? 1st or 2nd?
  7. mwvnos
    SC
    2nd i guess, i think they are easier to do the swap in. am i right?
  8. MaaseyRacer
    San Francisco, Ca.
    probably, i have never seen a 1st gen with an H22. Then again i have not seen that many 2nd gens with H22s in them. That is why i say you should do it.
  9. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    i dont know about the turbo??
    ive seen a H22 ina REX and its TIGHT literally
    no a/c ... p/s... battery in the trunk...
    if you added a f-a-l fan and ultra slim radiator it should work..
  10. phunky.buddha
    Dallas / Fort Worth, TX
    Good luck. The H22 into the CRX is a very tight fit. It'll work, but it does require some engine bay 'reshaping'. If you want to fit a turbo in there, you're probably going to be cutting out some sheet metal.
  11. paragus
    paragus Senior Member
    yea thats a super tight fit. but it would be bad ass.
  12. mwvnos
    SC
    i plan on cuttin the front end anyway. for a fiberglass front end. i hope to make it fit. if i get into it and find out i cant fit it with a turbo kit....ill juck the idea and go with a 5th gen civic hatch. hehe
