crx si 91 b18a1
Discussion in 'Civic and CRX - EF' started by crxsib18a1, May 11, 2010.
  1. crxsib18a1
    crxsib18a1 New Member
    il
    when i push on the gas it like chokes n me and about 2,00rpms it moves alittle????
    i did a b18a1 swap on it everything is wired rite idk wat else it can be?:mellow:
  2. D16SiHatch
    D16SiHatch New Member
    hows the mechanical timing? any codes?
  3. crxsib18a1
    il
    no not even a check engine lightis on i dont get it? i checked the wireing everthing is fine>>
  4. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I've came across a similiar problem like this. You sure you didn't accidently plug the TPS plug into the MAP and vice versa?
  5. crxsib18a1
    il
    il double check that but im pretty sure my friend pluged it in right il see..but thanks i changed the ecu to a pr4
  6. B16RacerN2NR
    Moving back West...
    Who did you get the motor from? If you got no codes, I say something is wrong mechanically. Like a clogged or restricted injector... You are using your Si harness for this swap correct? Maybe fouled plugs? Cracked distributor cap? Bad Spark Plug Wires? Ect...
  7. white rice
    white rice swapped ek
    york, pa
    i am wondering if you have an old si harness laying around. i need one for my b18 swap?
  8. crxsib18a1
    il
  9. crxsib18a1
    il
    mboy sold it to me in his car the motor was runing fine idk wat it can be its been like 2weeks its been sitting round so yea i am rechecking the harness no...lets see wat we find
  10. 78civic
    78civic Junior Member
    NW MS, Y'all
    I can't understand your first post.
    Describe again clearly with more detail please.
    E
