i got 91 Crx si with a b16a after having the swap and had it running for months it decides to quit on me while im driving, have it sit for a while and then it will run. the week before it happend i replaced the plugs with bosh platinum for 94 del sole vtch dohc. my first guess was replacing the coil, done that still same thing with less power than what i had and shut offs as well, second i replaced the ignitor, still same thing, so then i went out and replaced the cap, got msd ignition, coil, and cap, worked and then same thing again it shuts off after a while of driving, so then i found a place where i can get a obd-0 remanufactured distrubutors, bought one and put it in and took out all the msd stuff, it ran better than what it normaly did when i was replacing parts drove the sucker around and took it home to park it for about an hour and when i went to start the engine it started and then shut off on me and wouldnt start again, so found out that i can order the plugs that fit the b16a or which they say the best plugs for it online, i put the plugs in and it started fine and went to its orginal self, drove the car around turned it off many times and back on drove for at least two hours and runs great. i was very happy, and then this morning it wouldnt start same thing it cranks but nothing. battery brand new, new diributor, new plugs and wires, the only code its throwing is 7 which is the TPS sensor ever since my motor's first run, i have checked to see if im getting fuel and it is getting it. anyone would know anything? please this has been driving me nuts
