crx si question
Discussion in 'Civic and CRX - EF' started by ilovemyrex, Aug 22, 2010.
  1. ilovemyrex
    ilovemyrex New Member
    i have a 88 crx si that i just purchased and wanted to put a d16z6 i dont have the engine wire harness and was wondering do i need the dpfi to mpfi conversion or is the 88 crx si model already mpfi ????:confused:
  2. phunky.buddha
    Dallas / Fort Worth, TX
    88 CRX Si is already MPFI. You need to add VTEC to the system somehow, or convert to OBD1 and use all the electronics for the D16Z6.
    Welcome to Hondaswap!
  3. ilovemyrex
    yea i think ima go with the obd1 conversion.... know any websites that i can get the obd1 conversion and the z6 electonics???
    Thanks!!
  4. absoluteg
    absoluteg New Member
    i have a d18y8
    hey wats upp guy ok i have a d16y8 full swap harness,ecu,tranny,head,block. the motor runs but one of the rod berings went it has 125k on the motor and it has a brand new clutch on it only drove it around the block with the new clutch on im looking fora b16a1 for a trade that runs or juss needs a tranny or $600 takes all txt me tha name is derek and tha numba is 8453219273
  5. ilovemyrex
    well i have a d16z6 just the motor with no wireing
  6. absoluteg
    how much do u want for it bro
  7. Korax
    Korax New Member
    Western PA
    absoluteg, he isn't trying to sell you anything or buy anything from you. He is just wanting to know what to do to get his D16z6 working in his civic.
  8. D16SiHatch
    D16SiHatch New Member
    ^This is not the place for a classifieds ad.
  9. D16SiHatch
    Rywire - Online Store
    z6 dizzy and ecu you can find on eBay, craigslist, or the classifieds section here or over at honda-tech.
  10. ilovemyrex
    so thats all ill need is the z6 wireing the obd0 to obd1 conversion and the z6 ecu
  11. D16SiHatch
    what do you mean by z6 wiring?
    you need the stock harness with ecu jumper and p28 attached. then you run the wires from the jumper into the engine bay for 4 wire o2, vtec, etc. either switch plugs or run a dizzy adapter (which comes with the rywire kit) so that you can plug in your obd1 distributor.
  12. ilovemyrex
    ok so the stock si wiring
    it cause i bought the crx with nothing in it no motor or harness or ecu and i didnt want to buy the wrong harness and i already had the z6 but the motor only no harness eather and it come with the crx si manifold alredy .... thanx for the help
  13. Korax
    Korax New Member
    Western PA
    Just make sure you get the engine harness for a 88-89 CRX si. The 90-91 won't work either. Does the car still have a cabin harness?
  14. ilovemyrex
