Crx Si To B18a Wireing
Discussion in 'ECU's, Electronics, and Tuning' started by crxsi, Jan 21, 2003.
  1. crxsi
    crxsi Member
    ok... i didn't get my 92 b18a engine but i might be getting a 93 whole car thats totalled... my question is how can i convert my car to obd1 for this engine? do i use the entire wireing harness and ecu and im set or is there more to it? also the teg has an auto and i thought that the autos axles were different than the manuals tranny's, is this true? can i not use them with an LS manual tranny on my 89 crxsi?
    whats your opinion on buying this wrecked car?
    thanks
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    well you have to get a obd1 ecu conversion harness, goto locashracing.com and check there stuff out they have a converion harness, but they are pricey if you feel you have good soldering skills IM me and I will give the e-mail address of a dude who will make you half of the harness and then you will have to cut your old harness and solder the new half on.
    Good Luck...
