CRX Si Tranny Stuck in 1st
RFHOMI2U
Last night, I'm out cruising with some friends. I come to a stop sign and give it gas and pop out the clutch (stage 3 ACT). The car didn't go any where and would not and still won't come out of 1st. It isn't stuck all the way in 1st, I still have some play, but it won't come all the way out. It won't drive anywhere in first either. What happened here?? Is the tranny shot? Is it the linkage? Can I somehow get it out of 1st gear?? Thanks for the help...
how does you clutch pedal feel? normal? i'm not sure what would cause it to stick like that.
my repair manual says it could be any of these(faulty transaxle,faulty clutch disc,fork and bearing not assembled correctly,faulty pressure plate,pressure plate bolts loose)so it sounds like something with your clutch
