I wanna swap a b16 into my 91 crx si but i wanna turbo it i wanna know if a cable trans can hold this at 22psi?
I don't think you would have a problem with the tranny, but with the horsepower you would be running, i would consider aftermarket axles, and a really good clutch and pressure plate. With all the money you will have in the motor to run 22lbs, the axles, clutch, and etc will be nothing. Chris
