universal joint. To take the rack off, you just need to unscrew the bolt that holds the u-joint to the steering rack shaft from inside the cabin/under the dash. It's covered by the plastic boot. IIRC, it's a 12mm bolt, and there's two of them on the u-joint; one that clamps it against the column shaft and one to the steering rack/pinion shaft. Just take out the bottom one.
