Crx Tire Pressure Question
Discussion in 'Wheels / Suspension / Tires / Brakes' started by sportlinecrx, Jan 3, 2003.
  1. sportlinecrx
    sportlinecrx Banned
    ok...have an 89 crx dx. tire pressures in owners manual say 32/32 for the dx. car came with 175/70r13's
    now i have the same as the si's wheel and tire package (185/60r14's). owners manual says for si's, should be 28front/28rear.
    which pressures should i go by? the guys who installed them at america's tire made them 32/32 but is that correct?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    My stock wheels on my sol are 14's and i am almost positive that they recomend 31 psi.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Try out different pressures until you find the one that you like best... optimal pressures vary from tire to tire. With my Dunlop SP8000s, I ran 33psi cold- with the S-03s I run 36psi cold. Try out different combinations front and rear to get the best combination of turn-in, ride quality, mileage, cornering and straight line traction, etc that you want.
  4. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    I have an CRX Si, when i dont have my Mags on with proxxie T1's. i run the stock 185-60-14's at 30 Psi. SO ull b safe with 32.
  5. sportlinecrx
    sportlinecrx Banned
    thanks for the info and suggestions. im gonna try out different pressures to see what works best.
