crx to civic front end swap
Status
Not open for further replies.
yes u can
yeah it should just fit right on there, the only thing you would need to change I think
is just the bumper with the bumper support to go with it. But other wise they are
the same.
And that would eliminate that ougly civic lip you have in between the hood and the
bumper.
disagree
they're different chassis'...different fenders, headlights, radiator support, bumper support
you can probably *make* it work, but its not going to bolt on
i have it done it bolts on fine on top bottom ans sides but it has a gap where it meets the fender due to the fender flare on the civic
It will work, the mounting bolts are at the same spot but the length of the fenders on the CRX are shorter than the Civic. It will look allot nicer with a Civic front end and avoid all those ugly gaps. ;)
Status
