CRX weight
Discussion in 'General Tech and Maintenance' started by f22b1 coupe, Jan 12, 2006.
  1. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    does anyone know how much a stock CRX weighs?
  2. reikoshea
    Dallas, TX
  3. f22b1 coupe
    Indiana
    Well, i put honda crx lbs. to try to get it to fill in the blank, but it didn't work. What is curb weight? how is that different?
  4. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Curb Weight is the actual weight of the truck without any passengers or cargo in it. Its the base weight that is used in subtraction to calculate the total weight of the vehicle with passengers and cargo.
    Gross Vehicle Weight is the total weight of the loaded vehicle. This includes the vehicle itself and the cargo that is loaded within that vehicle.
    Gross Vehicle Weight Ratings are the ratings that are calculated by the manufacturers as to be the amount of weight that the vehicle will be when the vehicle itself is weighed filled with gasoline and loaded according to manufacturers specifications.
