CRX went through car wash and now wont start -with codes-
Discussion in 'HYBRID -> ED-EF / DA' started by Jdub752, Dec 30, 2006.
  1. Jdub752
    Jdub752 88 CRX DOHC ZC
    Beaverton, OR, 97008
    So i have an 88CRX DX with a fresh DOHC ZC and just installed my MSD cap, coil and 6a box. I went through the car wash and my car died when i got out and i showed codes 4 and 15. Now the car will not start and it ran perfect before i went in with no codes.\
    ANY IDEAS?
  2. Jdub752
    why do i now get 2 codes thrown?
  3. Jdub752
    I have another dizzy somewhere, but how can i prevent this from happening again? I cannot just avoid the rain, afterall I live in Oregon ;)
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    simple when you installed the dissy and cap did you check the ring seals? also after washing a motoer pop the cap and spray the inside of the dissy out with wd40
  5. eg6sir
    OEM ignition FTW!!
  6. ryangt
    ryangt Senior Member
    wire dryer, the spray can of it is 1.95 at autozone, grab it and spray the components dry, then youll be off like a prom dress.
    I suggest spending some time and weatherproofing all your connections. At least using some di-electric grease in the connections to keep moisture out. Its a cheap lill bit of insurance.
  7. Jdub752
    THanks for the input i got it home and it started up the next morning no problem!
    well it runs fine now i guess but im worried about when it rains..
    Oh and by the way my MSD setup was free except the cap so I dont wnt to hear it... and it does help my idle out a bit ;)
  8. ryangt
    grease
    like i said, di-electric grease in all the connectors to keep them dry, and make sure the distributor cap and boots are sealed as well. Then you can drive thru a lake and be running strong
