Crx Wiring
Discussion in 'HYBRID -> EG-EK / DC' started by iluvmyCRX, Mar 24, 2003.
  1. iluvmyCRX
    iluvmyCRX Junior Member
    For my B16 swap into a 91 CRX DX, do I need to buy the custom built harness from Hasport or can it work with just the SI harness?
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    http://www.hondaswap.com/articles/viewer.php?id=7
    there is one thing i have a question about and that is the tps sensor... if it has 3 wires and you swap them, which do you swap and to where?
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    i believe it is a green and a yellow wires that are reversed i will double check when i get back from class tonight...
  4. breakdancingbob
    breakdancingbob Member
    I have a complete b16a wiring harness I am willing to part with
  5. solblu
    solblu Senior Member
    Ricer
    Swap the outer two pins on the TPS for DX and similar harnesses (DPFI) only.
  6. MaaseyRacer
    San Francisco, Ca.
    yeah when i did my MPFI swap i had to switch the green/white and yellow/white wires on the TPS sensor...
  7. iluvmyCRX
    That does help some, but my real question is do I NEED the $249 Hasport harness or is all I need my DX harness, the B16A harness, and an SI harness?
  8. bury1
    bury1 Junior Member
    No, You don't need HAsport wiring harness, Hopefully your motor is a B16A1
    then what you need to do is add 4 wires (crank angle sensors from distributor 2 wires) injector wiring 2 wires this is called DPFI to MPFI do this conversion first look for more info on this. Then youll need to add all the other Vtec related wiring which is fairly simple. Look for this kind swap on a search
  9. solblu
    Ricer
    I have a write up on my page for a 4g DX to OBD1, most of it pertains to you, you would just use the parts from the b16 harness instead of the OBD1 harness
    here's the link
    http://www.knology.net/~jediklc/
  10. HOOKUPSPROCRX
    HOOKUPSPROCRX Member
    upland ca
    249.00 fpr the hasport harness what a rape!!! bring your dx harness to my shop and we will convert it for 150.00 and it looks 100% factory when we are done.909-373-RACE
