CRX with B16a Clutch/Flywheel question
Discussion in 'HYBRID -> ED-EF / DA' started by Sofast, Nov 16, 2011.
  1. Sofast
    Sofast Member
    I am swapping a 88-91 B16a obd0 into my 90 CRX. I Need a Clutch and Flywheel. Im using the B16 cable transmission. Can I use any B series clutch and flywheel? I looked at clutches and flywheels made for the 88-91 B16a and they are more expensive. Didnt know if any other applications would fit since they are cheaper.
  2. STC b series
    STC b series boost or bust
    Shittsburgh, Pa
    No you can not. All the flywheels are the same but you need a clutch to match the year of the transmission. Splines are different throughout the years.
