Im selling my 1990 DX CRX with a B18a 140hp motor. The motor is completely rebuilt and new clutch, pressure plate, pilot bearing, throwout bearing. The body has about 140k and looks descent for being an older car. The motor only has about 300 miles on it. Its only been on its second gas fill since the rebuild, so you have to break it in before you beat on it.The reason why im selling it is because I want to start on a new project. Have to many cars.
Parts list below:
ARP LS Head studs
New Timing belt
New oil pump
New engine motor mounts
New waterpump
New Bearings piston Rings
The car is OBD0 but I have a new jumper harness to make it OBD1,which I will include
New clutch kit
New oil pan
New oil pan gasket
New oil drain plug
New thermostat Gasket
New Thermostat
I will also include the Honda ECU chipping kit
New CV Axles
New Rear main seal
New valve cover gasket with tube seals
OEM Acura integra head gasket
New stainless steel exhaust header which I have not installed yet,I have everything bolted up to the stock crx exhaust
Has an LS cluster which everything works
I have all receipts for the purchases that Ive made. If your interested just email me at friendlyguy64@hotmail.com (NO PM'S) Thanks. Car is located in Tallahassee,FL
Parts list below:
ARP LS Head studs
New Timing belt
New oil pump
New waterpump
New clutch kit
New oil pan
New oil pan gasket
New oil drain plug
New Thermostat
New CV Axles
New Rear main seal
