The other day i tried to crank my crx with the b18b1 swap. When i tried to crank the car it wouldnt even turn over but when i got out the car i could see fuel dripping from the fuel filter which i could imagine the fuel pump is working. also when i looked on the dash the batter light was flash and also a couple of other lights that i'm not sure what it could be. Has anyone else had the same trouble and if so how did you fix it? If you have any helpful tips on what i should look for anything would be nice?
The line that runs to the fuel rail is streaming out at the fuel filter. Alot of people have been telling me that i need to replace the sealing washer gasket. Is there any way i could buy these at a parts store instead of buyinh a whole fuel filter? And if so what size would i need to get?
