crx wont start
Travisl
my crx wont start the crank turns but it wont start i just changed the fuel pump and checked the ignition any ideas
Did you test your starting/charging system? Do you know a base area where it is failing, such as fuel, spark, timing? Did you check your alternator belt? I need more details to point you in the right direction.
yeah the it has a spark im going to check the injectors tomorrow it started messing up on me it died in the street one day when i gotted started it was running slugish i think its a fuel rlated problem
sounds like the main relay or dizzy is shitting the bed...
